Why is my mac so slow?
Booting up takes 3 Minutes and opening a program like word or mail takes over 1 minute.
좋은 질문입니까?
좋은 질문입니까?
I would run the onboard diagnostics to see if something is not working correctly. Your system will go into CPU Safe mode which reduces the systems CPU clocking to a crawl!
To get to diags restart your system and press the D key on your keyboard at startup. Here’s a good reference Mac startup key combinations
Let us know what you got for an error/s
이 답변이 도움이 되었나요?
Cannot Load EFI/Drivers/TestSupport.efi
This is the error message I get
@maximmotyka - That sucks! Thank you Apple! 😖🤬😖🤬
Did you try the online version as well? I hate winging it! Let’s assume the drive is just badly fragmented, then defragging the drive would be what I would do. But before you do that make sure you have a good backup!
I would get this product as I find it’s one of the better ones! Drive Genius it’s what I use.
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 180
댓글 7개
Have you considered reinstalling the OS and switching to an SSD for faster read/writing speed?
dinoo_fixit 의
@dinoo_fixit - That’s a strong possibility but not the first thing I would do.
DanJ 의
@danj Right, but maybe after fixing this issue, replacing the ten years old 7200 rpm HDD with an SSD and increasing the RAM wouldn't be a bad idea
dinoo_fixit 의
@dinoo_fixit - I don’t disagree! The core issue is likely something else.
DanJ 의
@danj You're right
dinoo_fixit 의
댓글 2개 더보기
