주요 콘텐츠로 건너뛰기
10월 13일에 발표되어 10월 23일에 출시된 Apple의 2020년 플래그십 스마트폰은 6.1인치 OLED 디스플레이, LiDAR가 탑재된 트리플 렌즈 후면 카메라 시스템, 5G가 특징입니다. iPhone 11 Pro의 후속작입니다.
iPhone 12 Pro restarting everytime it's left to go to sleep
I have an iPhone 12 Pro that I’ve had since release (2.5 years) and it’s off AppleCare unfortunately. It’s been crashing when idle, to prevent it from crashing I have to have music playing constantly. When it does crash it will be bricked for anywhere from 5 mins to two hours. Sometimes forced reset works sometimes it doesn’t. Tried a restore, tried a DFU restore, reset up iPhone from scratch. Apple Store told me to pay $600 CAD for a back unit replacement but they weren’t 100% that that would fix it. I removed the sim and went e-sim and that fixed it for about 45 minutes before it started again.
Reset counter log:
{"os_version":"iPhone OS 16.5.1 (20F75)","bug_type":"115","timestamp":"2023-07-04 23:16:05.00 -0700","name":"Reset count","roots_installed":0,"incident_id":"86B9DEE6-1004-47C7-8864-FC79497CC754"} Incident Identifier: 86B9DEE6-1004-47C7-8864-FC79497CC754 CrashReporter Key: e9ee1cc9517feb23ea9192e05f55c159bd16495c Date: 2023-07-04 23:16:05.57 -0700 Reset count: 0 Boot failure count: 1
Boot faults: rst btn_rst,btn_seq_reset wdog,reset_in_1 sochot,reset_in_3
Boot stage: 0x50 Boot app: 2681261667 socId: 8101 socRevision:
Panic base log:
{"bug_type":"210","timestamp":"2023-07-04 02:54:19.00 -0700","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"A24FFBBD-AE82-49D8-88C9-FCA2E0BEFBC5"} { "build" : "iPhone OS 16.5.1 (20F75)", "product" : "iPhone13,3", "socId" : "8101", "socRevision" : "11", "incident" : "A24FFBBD-AE82-49D8-88C9-FCA2E0BEFBC5", "crashReporterKey" : "d6e60af9641022e05aada86a0c224793b6dcb83c", "kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101", "date" : "2023-07-04 02:54:19.07 -0700",
"panicString" : "Unexpected SoC (system) watchdog reset occurred during sleep/wake transition",
"panicFlags" : "0x0", "bug_type" : "210", "foregroundAppHash" : "2681261667", "repairStatus" : "2", "binaryImages" : [] }
And the important part of the panic full log:
{"bug_type":"210","timestamp":"2023-07-04 01:36:08.00 -0700","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"1D753E8E-40C0-408C-8EEE-D997B43EB392"} { "build" : "iPhone OS 16.5.1 (20F75)", "product" : "iPhone13,3", "socId" : "8101", "socRevision" : "11", "incident" : "1D753E8E-40C0-408C-8EEE-D997B43EB392", "crashReporterKey" : "d6e60af9641022e05aada86a0c224793b6dcb83c", "kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101", "date" : "2023-07-04 01:36:08.47 -0700",
"panicString" : "panic(cpu 0 caller 0xfffffff027ca2610): "port enable failed: 0xe00002d6" @AppleMultiFunctionManager.cpp:1657\nDebugger message: panic
\nMemory ID: 0xff\nOS release type: User\nOS version: 20F75\nKernel version: Darwin Kernel Version 22.5.0: Thu Jun 8 17:13:54 PDT 2023; root:xnu-8796.122.5~1/RELEASE_ARM64_T8101\nFileset Kernelcache UUID: 84B1F97A4EBB4332AE10EC38FF4B611D\nKernel UUID: 0450791C-9E84-3E6E-9611-412EC38EB3F7\nBoot session UUID: 1D753E8E-40C0-408C-8EEE-D997B43EB392\niBoot version: iBoot-8422.122.1\nsecure boot?: YES\nroots installed: 0
I’m in Canada so if anyone knows Canadian consumer law I’d love to write a letter
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Write a letter? To who? If it's never had one I'd try a new battery.
I had this problem on iphone7. Once almost 6 month
.. occurred then resolved first time that Maintenance person he changed data ic.. then second time without any interference.. then now a days...
But for every time an explanation that this cause from the hard desk
댓글 달기
답변 3개
가장 유용한 답변
While I can somewhat explain what's happening, there's not a lot of information out there about why it's happening. In your case a timer is going off that's never supposed to; the OS is set up to periodically reset that timer so it doesn't. This is a little different though, as the timer is being triggered not by elapsed time but rather by the sleep/wake transition.
You're right that the port enable failure is a vital clue, but unfortunately it's only useful for Apple; they keep that sort of information close to the vest, so for the rest of us there's no way of knowing what that port is. @flannelist may have some knowledge of the AppleMultiFunctionManager, but unless you've actually worked at Apple again they don't disclose that sort of information.
Regarding the back unit replacement, did you see the other person on Reddit who said they had the same problem that started after they did a back housing and screen replacement?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I haven’t seen that post, but if it’s a trend with back unit replacements it’s a step closer in finding a solution! Do you have a link?
@iphone12restart Yes, I can provide a link, but it was in a response to another post similar to yours and what information I gave was the sum total of what they said. Here you go.
https://www.reddit.com/r/ios/comments/xt...
댓글 달기
Its the wifi/bluetooth module im having the same issue and i looked into it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
After checking the Wi-Fi/bluetooth did it work afterwards? @lollol43710
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
No I ended up just getting a new phone unless you wanna get micro soldiering done if advise just to get a new phone like actually
댓글 달기
답변을 추가하세요
Bricked iPhone 12 Pro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 65
전체 시간: 2,966
