Bare minimum to test if phone will work
I want to test if my phone works after repairing the lightning port before putting it all back together. What is the farthest I have to go before I can see if it is working?
좋은 질문 입니까?
좋은 질문 입니까?
Hi Jacob,
I'd assume you would want to verify the functions on the lightning connector assembly before you close it back up.
So connect everything back up, then plug in the battery. Power it up; that verifies display, touch screen and battery. Toggle the silent switch and verify the vibrator works. Use the voice recorder and play it back to check the microphones and speaker. Confirm you have a cell signal. Plug it into a computer and make sure it sees and can be seen. Finally plug it into a charger and make sure it charges.
That'll cover all of the services provided by the lightning port assembly. After going through that list, you can be reasonably confident your repair was successful.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 28
