Hoverboard not turning on
Have green lights on charger till I plug into hoverboard and lights go out can anyone help me ๐
์ข์ ์ง๋ฌธ ์ ๋๊น?
์ข์ ์ง๋ฌธ ์ ๋๊น?
Could be the battery. If you donโt charge it very often then the battery can lose charge and if it drops below 30 volts the bms wonโt accept a charge. Will probably need a new battery. Open it up and check the battery voltage with a multimeter.
ํด๋น ๋ต๋ณ์ ๋์์ด ๋์์ต๋๊น?
Battery capacity is 25.2v, tested capacity is 24.7
You need a new battery as it's gone below voltage I'm afraid.
Thanks for that, will look for new battery ๐ค๐
Do you know best place to get one from???
24 ์๊ฐ ์ : 1
7์ผ ์ : 7
30์ผ ์ : 28
์ ์ฒด ์๊ฐ: 177
