주요 콘텐츠로 건너뛰기
Repair and troubleshooting information for the HP EliteBook 840 G6, an HP laptop part of the HP EliteBook series. Released in May 2019.
19 질문 전체 보기
Laptop power blinks white and orange, not turning on.
I have a new laptop, worked fine and then it was dropped. And now it no longer turns on. The power button would light up along with the caps lock light then turn off. I plugged in the charger and it shows no life. So i took the battery out and put the power adapter in and now the indicator light blinks white, amber, and then stays amber. Sometimes the keyboard lights will come on and sometimes it will not but the screen will never come on. Might I mention that while putting the battery connector back in, a light on the board would flash white and go away. Same with the power adapter. I'm not sure what to make of it, I contacted HP Support and they were no help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Check and count how many times the caps lock blink?
Then I will show you the error table.
Just once. It comes on for a few seconds then goes off.
댓글 달기
답변 1개
Hello @greykingdom
How many times does the caps lock light flash? I know that if it flashes three times, it is most likely that the RAM is not seated correctly. Just find the ram, remove it by pushing the metal clips away from the sides of the RAM, and it should pop out. Put the RAM back in, and the laptop may be functional.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Grey Kingdom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 53
전체 시간: 1,989
