주요 콘텐츠로 건너뛰기
이 Nintendo DS Lite는 2006년에 Nintendo DS의 후속작으로 출시되었습니다. 이 기기의 내부에 진입하는 방법은 간단하여 손쉽게 수리할 수 있습니다.
20 질문 전체 보기
Some questions about touchscreen not working
Sooo...
I was doing a shell swap on my ds lite and now the touchscreen doesnt work.
When changing the border around the bottom screen, a cleaar part came off with the border sticker which im guessing is the problem.
If anyone knows what happened can they please tell me wether i need to replace the screen or if its fixable with my current one.
Thanks to anyone who answers this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
what do you mean a "clear part"
댓글 달기
답변 2개
가장 유용한 답변
What you pulled off was the digitizer, I believe that all you need to do is reattach the digitizer which may require to be glued back down, check if the semi clear ribbon cable is still connected, if not then you have found the issue, please reply to this answer with a photo of the board on both sides.
Good luck
이 답변이 도움이 되었나요?
점수 1
댓글 달기
maybe you unplugged the digitizer or didn't plug it in at all,
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
THere was a clear sticker with a border and what looks like contacts under the border
Hmm I think you unplugged digatizer
댓글 달기
답변을 추가하세요
mynameiswhiskers11@gmail.com 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 89
