@neloadiele Hisense TV's are known for bad backlight strips. Let us know your TV's exact model number.
Hisense TV blink code for 7 and 8 blinks is a backlight issue. We know it is the backlight just based on that, but we can never assume that there isn't anything else going on.
First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. Unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 기존 질문에 이미지 추가하기 for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Sounds complicated, but it is not. iFixit empowers you to fix your own stuff. This community is behind you when you are fixing your devices. YOU GOT THIS!!!!!
