주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
AMD stock fan unable to spin on its own.
My AMD stock CPU fan has been having issues starting on its own. Moves a few mm on its own, kind of struggling to start spinning. Really wasn't thinking acted more in panic, opened panel and slight finger push was all it needed. I did check to insure cabling was all properly connected. Advice on how to proceed forward.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@pz781n usually this may happen if the CPU fan is in the wrong mode. In the Bios, there should be an option for 3 pin or PWM for the CPU fan. You can look at the fan connector on the fan cable, if it has 4 pins it needs PWM mode and if it has 3 it needs 3 pin mode.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Okay amd bios I have PWM and DC. I’m switch to PWM since I believe it has 4 pins. It was on auto. I’m shut down for a bit and then restart and see if that does it after few goes.
댓글 달기
답변을 추가하세요
PZ781N 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 41
