주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
Nintendo 3DS Top Screen Not Visualizing Correctly?
Recently my Nintendo 3DS (out of warranty btw) popped out of its hinge. Being handy with small electronics I decided to open up the 3DS with help via a YouTube video and was able to get the hinge back in its place. Unfortunately, when I powered up my 3DS, I noticed there were lines across my handheld, the images were not centered, images magnified and everything had a negative effect. What happened here?
If anyone can help with tips that I can do, please send them my way, calling or sending it in to Nintendo isn't an option right now. Thanks for reading.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 답변
The thin ribbon cable to your upper screen/LCD has been compromised. You need to replace the upper/top LCD. Click here, and select the Upper LCD Replacement guide to help you in this task.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
"AB Cellars" was correct. I ended up replacing the LCD screen. A lot harder than an iPhone screen btw.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
ey man I think I have the same problem but not sure, can I send you a picture of my screen so you can tell me if it the same please?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Have you fixed your problem? I think I have the same problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alexis Betancourt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 2,842
