이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
If you enable your phone hotspot while in the same room as the TV, does the TV detect that network? Do check your phone settings to make sure that the hotspot is not "hidden".
Dany 의
Hi @alcporter,
Does it "see" other WiFi networks OK?
Have you checked that the router's WiFi is turned on if it isn't a dedicated WiFi only router but is a dual Ethernet/WiFi router?
jayeff 의
