주요 콘텐츠로 건너뛰기
The Dell Latitude Series is designed mainly for professional use. This model is a 14" laptop released by Dell in 2018. The Dell Latitude 5490 emphasizes durability, portability, security, and is known for its long-life cycle.
Why is my keyboard typing wrong words
Whenever i press 7 it prints y7, whenever i press y it prints 7, whenever i press caps locks it prints 2 ,@ not typing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
@daniyalnaz89220 Did you spill anything on the keyboard? You can try an external keyboard, if the same problem doesnt come up with that, then the problem will be solved with a keyboard replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well Go to Control Panel and select the group Clock, Language, Region. Select language and choose Advanced Settings. Locate the option Override on Default Input Method and select preferred language from the drop-down menu. Set the Override for Windows Display Language to the same language, hit OK, and restart your computer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Maybe the keys were swapped out.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Daniyal Nazir Hajam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 117
