주요 콘텐츠로 건너뛰기
Released in 2021, the TUF F15 features an Intel Core i& processor, NVIDIA GeForce RTX graphics, and a 15.6 inch anti-glare display.
12 질문 전체 보기
How do I identify which fan is for which
my laptop is in need of a replacement fan but i have trouble identifying which is for my gpu ad cpu because i want to buy a replacement part and the fans for gpu and cpu are different.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Our best bet to tell would to have a look at the inside of the laptop, there are some hallmarks on the heat sinks. The GPU is usually more square, and the CPU is typically more rectangular. Depending on which GPU is in your machine, the GPU is also larger.
If you want to know for certain, remove the heat sinks. The actual CPU, or more likely the GPU, will have some manufacturer markings you can use to identify.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thanks ! That helped
@ghostrecon2497 Awesome! Let us know what you find so we can spread the knowledge! Someone else is bound to have the same question as you.
댓글 달기
귀하의 답변을 추가하세요
Ghost Recon 2497 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 31
