주요 콘텐츠로 건너뛰기
Apple의 2020년 주력 iPhone은 10월 23일에 6.1" OLED 디스플레이, 듀얼 12MP 카메라 시스템, 그리고 다석 가지 색상으로 출시되었습니다. iPhone 11의 후속 제품입니다.
iPhone 12 will not update after battery replacement
I changed the batteries on 3 iPhone 12's using good quality batteries from. 2 of the phones will not update to the latest IOS.
Because of the square edge design of the iPhone 12 and the new glue being used, I was concerned about how I would get the screens off without them cracking, so I heated the phones up to 90 degrees, used a pry tool to get the screen out of the frame slightly and then used Isopropanol to degenerate the glue.
I did not disconnect the screens when I did the battery replacement.
Could the Isopropanol be trapped in the phone causing some issues or is this because of the battery, which I doubt. The third phone seems to be ok.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 3개
I just have a few questions
Does it work if you update using iTunes and/or 3U tools?
What version of IOS are they on
Do you get an error of any kind
Have you confirmed they are not blacklisted
Is baseband working/does the IMEI show up in settings
Hi Sabastian, thanks for the help.
Not tried via iTunes or 3U Tools. Did not have this problem before the batteries were replaced.
They are trying to update to IOS 16.6.
Error message says "Unable to verify update"
They have tried updating at a different location to eliminate the possibility of it being slow internet connection.
I can not imaging why they would be blacklisted, they are not short of cash and these are phones used for a business.
Will get the other answers shortly.
The answer to the 2 other questions you had are:
The IMEI is visible
The current IOS is 16.6, which is strange, but...
I think I may have uncovered the issue. This person had Beta Updates switched on. Beta updates were then switched off for this update. The phone is showing IOS 16.6 installed, but still wanting to install 16.6. Could it be that a 16.6 Beta version is installed and now that Beta updates have been turned off, that the phone is trying to install the 16.6 version which is not beta, but it is unable to as a 16.6 Beta version is installed.
댓글 달기
답변 7개
가장 유용한 답변
I have the same issue with you, now I am running on ios 17 public beta 2 and unable to verify for upgrade to beta3 because of i am using the 3rd party brand battery.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
I wonder if the beta updates have some software in it that stop non-genuine batteries from being used?
It might be like that. What’s iOS version that running on your iPhone?
Finally, I can upgrade the fw by restoring from ipsw
How can I make my phone update after third party battery replacement
댓글 달기
Same issue here on iPhone 12, iPhone 12 Pro Max and iPhone 11. Did my whole family’s iPhone repairs and all had the same update bug. Contacted support and said it was done incorrectly and should go to Apple to get it done “right”. Then transferred to senior from a callback and was told it’s a know issue with 3rd party repairs and said it probably on purpose but should be saying that and the fix is to connect to iTunes to do the update and then all further update will work OTA from then on.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Same here on an iPhone 11 Pro after a battery replacement… the download would complete and would start to verify, but then would fail with no good reason given. Update through iTunes went fine. What an odd decision. I will try to remember to update this when the next OTA is available to see if that functionality is restored.
I have the same problem with an iPhone 11 Pro after an iFixit battery replacement, but I've been unable to restore it even with Apple Configurator :-(
I keep getting the dreaded:
Unexpected device state 'Recovery' expected 'RestoreOS' (Probably caused by corruption or panic in the bundle's restored) [com.apple.MobileDevice.MobileRestore – 0xFAD (4013)]
댓글 달기
I have solved this.
It has to do with Generic Batteries & the Beta version of IOS, probably find Apple are testing ways to stop us from installing Non-Genuine Apple spares.
  • Turn off beta updates
  • Ensure the phone is backed up
  • Download the latest IOS for that device (IPSW File)
  • Open iTunes (on Mac or PC) Restore the phone operating system from the IOS you downloaded.
    • Hold down the Option key and click Update or Restore if using a Mac, or hold the Shift key and click Update or Restore if using a Windows PC
  • Restore data from backup
  • Update IOS
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
So once I do that will all future updates work and Is it ok if you could explain it clearer please as I’m confused
When you say restore the iPhone operating system from the iOS I downloaded what does that mean?
Also it said iPhone cannot be synced I’m using a hp laptop to do this so unless u can solve this I won’t be apple to update my phone
댓글 달기
hello Roland,
Isopropanol is a good solution for the phone. Thanks to the appropriate physical properties, it oxidizes and evaporates almost instantly. It certainly won't cause any damage to the electronics. iPhone upgrade is available in batches. Important is the region of distribution and installed internal components, major chips. The fact that one of the three has already been updated can only mean that the other two are lower on the list of system servers (maybe the production date and serial number are also important, which seems to me to be logically related to the above). Check your WiFi connection and make sure your battery has more than 30% charge. These are the necessary conditions to run the upgrade query.
Connecting the battery with the screen connected is completely normal - you can't assemble the phone in any other way. It would be dangerous to connect the screen while the battery is connected! It would be extremely irresponsible that way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I would check the settings on the phone to see what current software the phone's are using. Sometimes if there's beta software on the device it's a pain getting them to update to new ios udpates. The chance of the alcohol messing with the device is unlikely as it's safe to use on electronics.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The same thing is happening for me I went to get my battery replaced on Monday and I tried to update to iOS 17.5 beta 1 after finishing it took ages to verify the update and it failed to verify than it said unable to verify update iOS 17.5 beta is temporarily unavailable. Please try again later I’ve tried it multiple times and nothing has worked I’m thinking of getting a MacBook to do the update via iTunes but I don’t know if that will work I just want to be able to update my phone
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
You can use a PC, the best way for less hassle is to temporarily put the old battery in the phone, do the update then put the new battery back in. Or just reset you whole device through factory settings using iTunes restore
댓글 달기
I had an issue with my iPhone mini 13 not wanting to verify iOS 17.5 OTA. I had just replaced the battery too. It was not the battery though. The iPhone just needed to be upgraded using the Mac. Hopefully future upgrades can be done OTA now.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I’m having this issue as well however it’s not even updating using iTunes it’s not loading the iOS software period in recovery mode
댓글 달기
답변을 추가하세요
Roland Chandler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 123
전체 시간: 7,727
