주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Why isn't my hard drive being recognized and lcd not lit? help!
Hey Guys,
I recently had the great idea of trying to get my old MacBook 13" 1.83GHZ Core Duo back into commission. I went out and bought a new hard drive because the hard drive seized up a while ago and i didnt have money to replace anything. I ordered a new battery and power supply from amazon and that's on the way. For the time being I can use my dads macbook charger to power my macbook.
When I plug in my computer and power it up, the lcd powers up and the backlight powers up then the backlight turns off. So I hit the power button, gray screen turns on powers up, then backlights off but the folder with the ? comes up. (New hard drive so i figured that'll be normal.) That's problem number 1.
Since I have the new hard drive, I figured I have to re format it. I popped in leopard start up disk and went ahead to select language. I agreed to terms and brought up the screen where I choose destination, but my hard drive isn't recognized. It's spinning so it's powered but not registering. What do I do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You need to format it using disk utility on the leopard start up disk. Once you format using disk utility it will be recognized for you to install Leopard on to it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
How do i do that? I cant find the disk utility anywhere
nevermind. found it haha. Now I just have to figure out the backlight issue
Glad you found it and it worked for you. Hopefully someone will be able to help you with the backlight issue.
댓글 달기
귀하의 답변을 추가하세요
OgCorndogg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 632
