주요 콘텐츠로 건너뛰기
The Rock Band Fender Stratocaster Wired Guitar is a guitar-shaped controller for the Rock Band video game franchise for Xbox 360.
Rock band 1 wired guitar will not turn on / connect.
I have a Xbox 360 wired Rockband 1 fender, it’s been 5ish years sense I last used it but I dug it out to play clone hero on, but when I plugged it wasn’t working, the light for the Xbox 360 logo on it would flash for a second and then shut off. I first tried a different break away cable end but I got the same result, I tried the classic wiggle the cable around to see if holding the cable in a specific way would make a better connection but I had no luck with that. I took the guitar apart and looked at the main board and there were these 2 capacitors that’s caps had turned a purplish black, all the other ones still had silver caps so I’m guessing that may be the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
I have the exact same problem let me know if you solve it please and thank you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Did you fix it yet?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the exact same, but only the c52 is black. I'm gonna change it and tell you if that worked
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sleepless Gamer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 41
전체 시간: 945
