주요 콘텐츠로 건너뛰기
로지텍 MX Master 3S 무선 마우스 수리 및 분해 정보입니다. 2022년에 출시되었으며 모델 번호 MR0077, 부품 번호 910-006557, 910-006558 또는 910-006556으로 식별됩니다. 출시 당시 캐나다에서 판매된 그라파이트 버전의 경우 810- 008296처럼 다른 지역 또는 모델 버전에는 약간 다른 부품 번호가 있습니다.
What kind of switches does Mx Master 3s use?
What kind of switches does this mouse use and what is their estimated number of clicks? This question is also related to side navigation buttons. In my experience these buttons typically break first.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 1개
선택된 해법
I used this part number "EVQ-P0D07K" to fix the failing switch in my 3s. It works as a replacement to the OEM but it has a higher operating force and a louder click.
I wish I had gone with the similar "EVQ-P0E07K" which has a lower operating force and is rated for 5M cycles rather than only 1M.
There may be other alternatives out there too.
Edit to add: this is for the left and right click, not sure what the other switches are.
이 답변이 도움이 되었나요?
점수 9
댓글 6개:
Ordered, installed, works! Thank you.
Went with the EVQ-P0E07K myself, and tolerated my MX master 2S which has yet to have switch failure unlike the MX master 3S. The replacement switch click is much more satisfying, and seems to be working well. I replaced both left and right mouse button. Right mouse button started failing first by failing to register clicks, Left mouse button then started failing by bouncing and registering double clicks where they were not intended. Also, both were failing with drag operations, where the switch would let go prematurely.
Quick follow-up to the OP and @dgood: does replacing the switches need soldering or can you just unscrew the old switches and replace them with the new ones?
you need to solder it - a cheap soldering should do the work
I just replaced my left switch with a Kailh Silent 6x6x7.3 from China, works well, is silent maybe 10% heavier to press, but acceptable. You can buy 10 of them for 2 bucks.
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Artem Kliatchkine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 11
지난 7일: 88
지난 30일: 337
전체 시간: 2,792
