주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
20 질문 전체 보기
No signs of life
Hello all, I purchased a faulty Mac mini and am currently working on a diagnosis and just had a few questions. Firstly, if the ram is faulty would the machine show a white light and beep like previous models of Mac mini. Also, is there a way to know for sure if it’s a logic board or a power supply?
Thank all :)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I left it plugged in for a while and came back to a flashing white light on the front in the following sequence: 3 short pulses, 3 long pulses, 3 short pulses
댓글 달기
답변 1개
가장 유용한 답변
As far as I am aware these machines do beep with faulty RAM. Though I admittedly don’t have personal experience with these specific power supplies or logic boards I think it should be possible to test the voltage if you can find a pin out and test the PSU with a multimeter.
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
To add to what @thequacker Here's the Tone codes (Beep) If your Mac beeps during startup and heres the White LED code Mac mini power LED indicates the computer's status
Thanks for this, I have attempted to plug it into another mac using a usb-c to usb-c cable however it immediately appears to lose power. Would this point toward a faulty power supply? Thanks
@owenmason87347 - I would start there!
Hi, sorry for the delay was waiting for the part. I have now fitted a new power supply. It is no longer immediately losing power but will only show a blinking white light (in sos pattern) and will not show up in apple configurator when plugged in. Could this be a firmware issue? Thanks :)
@owenmason87347 - Apple Configurator is only useful in T2 based and M Series systems. So that won’t help you in this Mac Mini system.
Let’s give this a try remove the RAM and disconnect the drive and try to start the system again did that work?
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Owen Mason 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 166
