주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Compaq 8200 Elite는 고급 사무 및 디자인 작업을 겨냥한 소형 폼 팩터 워크스테이션급 데스크톱 PC입니다. 기술자가 드라이브와 카드를 빠르게 교체할 수 있도록 설계에 중점을 둔, 상당히 수리가 용이한 기기입니다.
My PC beeps and won't start
When I start my PC it's not working and beep sound is coming and not starting any solution?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 15
댓글 2개
Yes beep sound coming and not starting
انا عندي 5 رنات و يتوقف وتم التاكد من الرامات و شغاله و غيرت الباور صبلاي و برضو المشكله موجوده
댓글 달기
답변 1개
선택된 해법
Hi @einsteinl
Count the number of beeps that you hear.
There will be a pause between the series of beeps and then it will start the beeps again e.g. 4 beeps > pause > 4 beeps > pause or 2 beeps > pause > 2 beeps > pause etc.
This is a fault code and the number of beeps will tell you what's wrong.
This page of the hardware maintenance manual details beep codes 1-4, the next two pages cover beep codes 5-11.
이 답변이 도움이 되었나요?
점수 12
댓글 4개:
@einsteinl
Try either reseating the memory modules or testing if each one is OK.
Reseating the memory means removing the memory modules and then reinserting them.
If that doesn't work, if there is more than 1 memory module installed, remove all the modules except 1 and then see if it turns on OK.
if not remove that module and try the next one - you may have a faulty memory module.
The manual I linked shows how to remove/replace the memory modules
IMPORTANT!!
ALWAYS turn off the PC and DISCONNECT THE POWER from the PC BEFORE removing/replacing any memory modules. Once you have finished removing or replacing a module, only then reconnect the power to the PC and turn it on.
Removing memory modules with the power still connected, even if the PC is off is a good way to cause damage to them or other components on the motherboard
I cleaned the rams and then it started
I tried it and it doesn't work, noting that the alarm counts 9 times and then stops, and so on.
انا عندي5 رنات ثم يتوقف
댓글 달기
답변을 추가하세요
Einstein l 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 71
전체 시간: 3,251
