주요 콘텐츠로 건너뛰기
Apple Time Capsule Model A1302의 수리 및 분해 안내서. 대부분의 정보는 Model A1254에도 적용됩니다.
19 질문 전체 보기
Is it possible to install an 8TB hdd?
I have a 2009 Time Capsule with the 1TB HDD and I am wondering if I can upgrade the HDD to 8TB or if there is a capacity limit? It seems like there is conflicting information where some have reported that there is a 3TB limit while others have said there is no (feasible) limit. I don't want to waste money on something that isn’t compatible. I am aware of the SATA II limitation. Thank you for your help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The different series of the Time Capsule have different limits. The first three versions if I remember correctly are 3TB. The fourth and fifth can be boosted 6TB as that is what I had done. You maybe able to go higher.
Make sure the drive fully supports SATA II systems, many don’t.
Wikipedia - Time Capsule specs
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks Dan. So I guess my 2009 2nd gen can only go to 3TB. Still plenty enough for me I guess.
댓글 달기
귀하의 답변을 추가하세요
Duck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 58
