이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
@alexlinnecxr not sure what a "dipped headlight" can you explain this? Is this a new issue with your Corsa? Anything that happened to it? You made sure you do not have daytime running lights on the Corsa. what have you checked?
@oldturkey03 my car does not have day time running lights they simply just won’t turn off the dial doesn’t work to switch them off once the ignition is on completely confused, as I’m quite good with cars but not wiring at all
oldturkey03 의
AlexLinnecxr 의
