주요 콘텐츠로 건너뛰기
Released in 2020, the Razer Blade 15" Advanced model is designed to provide gamers with powerful specifications and sleek aesthetics.
Ifixit 2020 Razer Blade 15 Advanced battery compatibility
Has anyone tried using the RC30-0248 Razer battery ifixit sells for the early 2020 Razer Blade 15 Advanced on the 2019 Razer Blade 15 Advanced that has the same RC30-0248 battery in it? Ifixit cannot confirm capability. Seems it should be fine.
Thanks
Replace a 5209 mAh battery compatible with your Razer Blade 15" Advanced model Laptop. 80.2 Watt Hours (Wh). 15.4 Volts (V). Part #RC30-0248. 이미지
제품
Razer Blade 15" Advanced Model Laptop Battery
$92.99
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Did you ever figure it out?
댓글 달기
답변 1개
Using a battery not specifically confirmed by the manufacturer for your device can be risky. While the RC30-0248 battery may physically fit in both the 2019 and 2020 Razer Blade 15 Advanced laptops, there can be differences in voltage, capacity, and compatibility that are not immediately apparent. It's best to contact Razer's official support or check with Razer user forums to see if others have successfully used the RC30-0248 battery from iFixit in the 2019 model. It's essential to ensure compatibility to avoid potential damage or safety issues.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bloatedbattery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 373
