주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
Why is my new battery not working?
The original battery still works, but the trackpad stopped clicking. I suspected it might be swollen, so I removed it. However, it did not appear swollen. I decided to replace it anyway due to the trackpad issue.
I installed the new battery, but when I connected the charger, the light turned green instead of amber as it should have when charging. Additionally, I was unable to turn on the computer. The trackpad worked with this new battery.
After a few hours, I removed the new battery and reinstalled the original one. Everything except for the trackpad worked normally.
I contacted the store where I bought it, thinking that I had received a defective battery. They sent me another one, but the same thing happened again."
What could be the problem?
Original battery: A1321, 10.95V, 77.5Wh
Replacement battery; A1321, 10.95V, 59Wh, 5300mAh
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Let’s get a better view of things, if the system boots up with the charger let’s install this gem of an App! CoconutBattery take a snapshot of the apps main window posting it here so we can see it.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The computer is completely dead when the replacement battery is installed, it won´t start even with the charger.
Works fine with the original battery or no batery/charger only.
@mrsparanoi84129 - let’s start there!
댓글 달기
답변을 추가하세요
MrsParanoidAndroid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 169
