주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1920, A2097, A2098, A2100. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S"로 발음합니다.)
398 질문 전체 보기
Phone Screen Flickering Green
My phone just randomly out of the blue started flickering green and I turn it on sometimes and actually get into the phone but the brightness automatically goes up and then my phone goes back to flickering green.
Any help would be greatly appreciated because I can't afford a new phone at the moment.
UPDATE : The screen has gone black and is not displaying anything at all any fix?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi Snake,
Can you tell if there's any other signs of life in the phone, like vibrating when you flick the mute switch or maybe when you plug it in? Those sort of reactions would say that the phone is basically okay but in need of a new screen, because that's what it sounds like based on your description.
Follow the step by step directions in the screen replacement guide to fix the problem.
iPhone XS Screen Replacement - iFixit Repair Guide
The good news is that the X series phones are old enough now that the price for even the soft OLED screens have dropped to the point of being reasonably affordable. You can support iFixit's repair efforts by purchasing one from them, or you can save a lot by checking around at sites like Amazon, eBay and AliExpress, among others.
There are a couple of caveats you should be aware of though. First, there's a piece of data called the MtSN that needs to be copied from the old screen to the replacement in order to reenable the True Tone function. This requires a device programmer such as the JC V1SE or the QianLi iCopy. If you're willing to live without True Tone, then you don't need to do this. Note that the MtSN can also be read from the phone so it can be restored at some point in the future as well.
Secondly, Apple has continued their repair-antagonistic practices by pairing the screen to the logic board. That means you will get a pop-up warning every time you boot to the effect that the screen may not be a genuine Apple screen - even if it is a genuine Apple screen. After a couple of weeks that warning will go away, but you'll still have the badge that appears on the Setup app and the warning that will show up in the Display settings. However, the display will work correctly other than the bogus warning.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hey there,
Thanks for letting me know on how to fix it. It vibrates and everything just randomly stopped displaying. I'll for sure attempt to fix the screen but still unsure why it stopped displaying randomly out of the blue.
@snake68586 I understand, you may not figure out why the screen died. They're made up of several very thin layers of glass and plastic with delicate electronic connections that are all too easy to break. Could have been a result of being flexed a little too much like being sat on, or a drop, even a minor one, or liquid got in, maybe too much humidity or perhaps just the random phase of the moon.
So yeah, if it was mine I'd go ahead with a new screen and see where you are after that. All indications are that everything else is fine and a new screen will get you going again.
댓글 달기
귀하의 답변을 추가하세요
Snake 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 52
전체 시간: 156
