Computer wont turn on after coolant liquid replacement.
I have a liquid coolant system for my pc. So a couple of days ago the computer started to turn off as coolant was not working. So I order replacement coolant and tend to refill it but I had no idea about static and I think during the process something has happened now that power supply takes the electricity and motherboard lights turns on but it wont startup with power button.
좋은 질문 입니까?
점수
0
@mario22281 Did you make sure that all the cables are plugged in where they're supposed to be?
Andrew S 의
Yes Andrew I took a picture before unplugging.
Mario 의
When a computer is turned on things happen. What you posted says that the PSU is working and supplying 5V. What else is happening???????
Do your fans run == 12V is working.
Do you hear a post beep? == CPU is working >> because of your coolant problem, there is a high probability of a problem here.
What MB lights are working? == Disk activity light?? Disk is being accessed.
bill 의
I will add a video link to see it. There is no beep or disk access.
Mario 의
no beep or disk access would point to the high probability CPU not running.
It doesn't take long to fry a CPU without coolant.
bill 의
