My black E7 headphones won't play any sounds
The lights turn on but it won't play any sound
좋은 질문 입니까?
좋은 질문 입니까?
Hello, after doing some searching, I've found that it may be a bluetooth connection issue. What this means is more than likely an issue with the device you're trying to connect to instead of the headphones. I would recommend checking if all your software is up to date or a simple reset should do. If the problem persists, then I would recommend following this troubleshooting guide. I hope this helps!
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 22
전체 시간: 108
