주요 콘텐츠로 건너뛰기
Model A1288 / 8, 16, or 32 GB capacity
451 질문 전체 보기
How do I remove the password from my iPod Touch 2nd Generation?
My son put a password on my iPod Touch 2nd Generation 16G. I can't remove it. My PC & iTunes won't recognize my iPod, and I can't update or reset it. The iPod won't start up—it only displays the Apple Logo.
Appreciate any help.
THX
Dean
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 달기
답변 6개
선택된 답변
To restore a password-protected iPod Touch:
1. Plug iPod into computer.
2. Hold down the power (top) button for about 5 seconds until you see the "slide to power off button"
3. Slide the red button.
4. Immediately hold down both power (top) and home buttons until you see the apple logo.
5. When you see the apple logo, release the power (top) button, but continue to hold down the menu button until you see a picture of a USB cable with an arrow and iTunes on your iPod.
6. Then restore your iPod with iTunes (remember this WILL erase everything off of the iPod, but hopefully your music is backed up on your computer/iTunes).
Hopefully this helps!
해당 답변은 도움이 되었습니까?
점수 16
댓글 7개:
Unfortunately, that's the only way to get rid of the password!! Sorry!!
it works yes soo happy thank you!!!!!!!!
we did this and there is still a password...i dont understand what is going on with it!
Hailey, what OS is your computer using? If you asked your own question I am sure you would get more help. Right now it shows up as an answer. So please ask your question, because there might more than one solution. Good Luck
My ipod says ipod disabled connect to iTunes don't have I tunes what do I do
댓글 2개 더보기
댓글 달기
Try putting i device in dfu mode
1. turn ipod off
2. hold power button for 3 seconds
3. while holding power button hold home button for another 10 seconds.
4. release power button hold home button for another 15 seconds then itunes will recognise and you can use as new ipod : )
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Restoring is supposed to erase all the contents stored on the iPod Touch, including the password. If that fails, try taking it to your nearest Apple Store and have them try. I suspect that you may have some sort of hardware issue. Try restoring again, and if it still doesn't clear the password, use my suggestion. Otherwise get a new iPod Touch. Good luck!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Jon Fukumoto, There are a few more possibilities that could be explored before getting a new iPod.
댓글 달기
Do the first answer, by forcing a restore. But DO NOT when it asks to, restore from backup. As this is all settings including passcode.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i had the symbol but it still said I was locked out for 36 minuets does it still mean it works?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have same problem but i dont want it to get icloud locked or anything so im a bit worried
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dean 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 29
전체 시간: 73,323
