주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
volume/power dial broken
Hello, the volume/power head has snapped in two after a fall from standing on an uneven rug to flat on the floor.
The dial is in two parts almost evenly. One half still attached, the other loose.
Motor functionality via Ortho remote fails as does physical manipulation of the dial. the dial believes it is at 100% and returns to 100% after physical rotation of the (remaining) dial and when using the ortho remote.
The Unit suffered no external damage aside from the dial.
However, when attempting the Loop functionality from playback on FM and BT, the unit automatically enters Playback Speed Mode.
I can hear the volume motor working away when i have the device on line in with no input active.
Kind thanks,
Aaron
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
I’m experiencing the exact same issue — the radio fell and the knob came off. I tried to repair it using super glue, which holds the knob in place mechanically. It snaps into the ‘off’ position, but the dial itself no longer functions. As a result, the radio won’t turn off and the volume stays stuck at 100%.
의
@retoschneller Exactly the same thing happened to me, can this volume knob be repaired?
의
댓글 달기
답변 2개
had the item repaired at cost by manufacturer, i think was around £80 inc transport. turnaround was very quick and since ive had no problems and been extra careful.
have contacted support and requested a feature add, a stand to slot the OB-4 into to keep it upright and topple free,
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I contacted Teenage Engineering directly via their websites 'contact us' page
의
댓글 달기
How did you reach them? There isn’t any direct customer service info listed, just a redirect to ifixit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aaron Benn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 72
전체 시간: 932
