The Makita JV0600 and JV0600K are variable speed top handle jigsaws, designed for cutting materials such as wood, steel, and aluminum, with a stroke length of 7/8" (23 mm) and a range of 500 - 3,100 strokes per minute.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Is this jigsaw clogged with debris? Can you clean off as much debris as possible then try a little WD-40 into the release lever and blade jaw? Some light rapping against the body with a mallet can help loosen dirt buildup with WD-40 loosening up a sticky mechanism.
F Dryer 의
