주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Why is my screen black after dropping and cracking it?
I cracked my iPhone 4 screen a month ago. It's worked fine, with the crack stemming from the earpiece area outward due to my money clip applying pressure to it in my pocket. I've dropped it a few times since then, and now the screen is black although I can still place calls using voice control and even use the touch screen using my memory of where things should be. Sometimes the screen will come on for a few minutes. A hard reset worked and then it went black again. I have also tried restoring it to factory settings. How do I fix this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Replace the screen. You were fortunate it didn't go dark right off.
If this Answer is helpful please remember to return and mark it Accepted.
iPhone 4 (GSM/AT&T) Screen 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you so much!
댓글 달기
my screen black out from droppin it but it still my sound when it chager up
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
lederrick - You placed a Question where only Answers belong. Please read through some other answers about replacing displays. . . You may have only dislodged a connection. Obtain the proper tools, open the unit and inspect it.
댓글 달기
귀하의 답변을 추가하세요
Joe Makdisi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 9,473
