이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Are you comfortable disassembling, diagnosing and troubleshooting electronics? This may be as simple as a worn out or damaged power adapter in the unit that switches between charger and internal battery power. Using multimeter can help trace where power from the battery is lost or disconnected.
F Dryer 의
