주요 콘텐츠로 건너뛰기
Hewlett-Packard began manufacturing personal laptop computers in 1993.
3332 질문 전체 보기
질문 마감됨
HP ProBook 6560b boots into windows boot manager?
When I turn on the probook,a big black page is asking me to,
* Reinstall windows
* Contact the manufacturer(I'm not sure how)
* Click repair your computer
The error is:00cx0000225
info:storage has been removed,corrupted or it is inaccessible.
If you know what to do,please tell me.I have the status code.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Well, sounds like the Windows installation on your boot drive is corrupted. So, I would recommend booting with a copy of a Windows (same version) cd and go into recovery mode and run chkdsk on the drive.
This probably won't fix your boot issues, but, would clean up the drive.
Next, if Windows still doesn't boot you may need to do a re-installation. If you have data on the drive you can burn a bootable copy of Ubuntu Linux. With this, you should be able to access your user data on the windows drive and copy it off to another drive or a USB stick.
Once you back up your data you should be able to press (I think) F11, or another key to have your HP boot into the Windows recovery partition where it will let you factory re-install windows.
If the recovery partition is missing...you'll either have to order the factory installation CD for that specific model from HP or install Windows 7.
Why Windows 7? Well, I worked on an HP a couple weeks back and tried to install Vista Home Premium back on the machine using a retail disc and 1, the install would stop at 75%, and 2, I couldn't get the driver for Vista (off HP's web site) to work for the built in Wi-Fi. Thus, I just opted to install Windows 7 where it picked up all the devices.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
In Windows recovery you can do a "Repair", but, I would highly recommend the first thing is to backup your data.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 2,813
