Can I put a 128gb or 256GB logic board into a 64GB iPhone 11 model?
i have a water damaged iPhone 11 64GB, im looking to relace the logic board in it. im wondering if I will encounter any problems if I did this?
좋은 질문 입니까?
좋은 질문 입니까?
Hi Jamie,
Okay, in terms of the hardware, yes it is 100% compatible and the memory size has no relation to any other part of the phone so any version will theoretically work.
I say theoretically because Apple has gone on a rampage locking down parts to the motherboard. If the motherboard is the only thing you change out, you can expect the following issues to show up.
You can keep the Face ID if the logic board you purchase comes with the front camera assembly and the earpiece speaker assembly that are paired to that motherboard.
True Tone and Auto Brightness can be reprogrammed with a device programmer such as the JC V1SE or the QianLi iCopy.
The battery is a bit trickier, as you have to have the BMS board off the original battery, which you're not likely to get with a replacement logic board. You'd have to have Apple replace the battery to eliminate that problem.
Getting rid of the screen warning would require replacing the Touch Module on the display with the original; again, not a part you're going to get with a replacement motherboard. Again, the only way to get rid of it would be to pay Apple for a screen replacement.
So yeah, in general most phone functions will work outside of the obvious loss of Face ID and some annoying warnings, but you should know what you're getting into with trying to buy a replacement logic board.
해당 답변은 도움이 되었습니까?
thank you! Its a preenagers phone that's been fixed already... Not holding hope tbh... This is a plan in theory, once I've opened it up! can't afford another £200 to fix the phone. I'm hoping if I open it and clean it, it will work. What are your thoughts on Alibaba's logic boards? There are a few on there.
@jamiewilcockson I frankly haven't looked on Alibaba itself, but rather on its retail site AliExpress. You can find boards that may be suitable, but read the listing carefully to make sure the board is not iCloud locked and that it's not a bare test board; i.e., just a circuit board with no components on it. There will also be choices as to whether you want to buy a board with or without the rest of the Face ID components, which, of course, will be more expensive. Oh, the other consideration is to try and verify any board you buy isn't SIM locked to a specific carrier.
24 시간 전: 1
7일 전: 3
30일 전: 36
전체 시간: 210
