The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
Same answer as Kamal. The CPU is obviously working as the fan increases speed indicating it is getting hotter. But the twist is the display. You need to be a little more observant and post what is happening to the disk activity light. Also, what have you don't - like checking cables, swapping monitor to another computer, etc.
And it would be better to start another thread as this one is old.
Ii did that but the fan with water then i got the same error on my hp compac elite 8200 sff pc
Khurram Iqbal 의
5 months later, I don't know what you are trying to communicate.
If my previous answer worked, it would be proper to score it.
bill 의
When I turn on my CPU, the fan starts and after some time the fan becomes high. There is no display on the monitor.
Kapil Kumar 의
bill 의
