The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
@nicholasmwendwa, is this happening when the phone is plugged in and charging? Or is it happening while it's only using the battery?
Did you also check the back of the phone for possible warping due to a swollen battery?
Note: It's always helpful to add some details about what was going on before the overheating started. For example: Did you drop it? Was it in a hot environment for a long period of time? Did you get liquid inside?
Answering these questions can help the Community to better troubleshoot this issue.
Kris Rodriguez 의
