이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Kevin, telling us the board is fried isn't going to get you any help. What happened to it? How do you know it's "fried"? What have you done so far to diagnose and/or fix it? If there's obvious damage to the circuit board, post a picture of it so we can see what you see.
i have a similar issue, and have opened up the product to attempt a diagnosis. ours had a problem after accidentally plugging in a wrong adaptor that fit, though had different voltage regulations, and afterward saw the unit powered on and off instantly, with a smell of burning plastic afterwards. upon opening and using a multimeter to look for current while having the unit powered by batteries, it looks like a micro square resistor was being burned after probing the regulator chip, so it seems to be unregulated powered from resistor damage, at least, to the best of my knowledge
기존 질문에 이미지 추가하기
Jerry Wheeler 의
@dadibrokeit
SkyWaveBird DX 의
