TV does not start - backlight blinks 3 times, red standby LED turns on
I have a UN55MU7600FXZC (Rev FC04) that died (assuming after a power surge) -> no red standby light
I tried all standard basic diagnosing (change plug, change outlet, change cable, change everything)
I opened the TV found the following:
Power supply Board:
  • model: BN44-00876D
Main Board:
  • type: BN94-12395C
  • model: BN41-02568
  • code: BN97-12813A
I tried disconnecting the main board from the power supply and I can observe all backlights coming on though the holes in the back
I took out the power button and tested for connectivity.
I replaced the following parts:
  1. Power supply with identical model (though it was the power supply)
    1. Checked all voltages on the connector that goes to the mainboard and are all in line with what is expected based on other articles here
    2. Checked voltages going to the backlight and they are in line with what is on the board (and the backlight turns on so that should be ok)
  2. Main Board with a SIMILAR model (BN94-11914C) which according to the Samsung parts website, is compatible with my model (Samsung BN94-11914C Main Pcb Assembly). In fact the label on the new main board lists my tv model: UN55MU7600FXZC
After replacing the main board I am getting different symptoms:
When plugged in, the backlights turn on or a second, they go off for a second, they turn back on at half brightness for a second, they turn off, and after another second the red standby light comes on. When the red standby light comes on, you can hear a buzz from the power supply (as if it tries to power on) and then the buzz goes away, the standby light goes off. Wait 5 seconds, the cycle starts again.
Things I tried (with both power boards)
  • Press the power button - no change, cycle continues uninterrupted
  • Press the power on the remote control - no change. (Although you can see the IR sensor on the tv blinking rapidly when the remote control button is pressed.
  • Disconnected the speakers from mainboard - no change
  • Disconnected the wifi module from main board - no change
  • Disconnected the mainboard from power supply - backlights come on, solid, stay on.
  • Disconnected the backlight connector from power supply - nothing turns on.
Someone on the internet suggested this could be a faulty screen... but I find it hard to believe. could it be that the main board is a different code than my TV that is causing this? Even if the Samsung website recommends them as compatible?
Thank you!
EDIT:
Note: I temporarily disconnected the speakers and the WiFi module since they seemed to have no impact connected vs disconnected
Video with behavior when plugged in:
(documents.cdn.ifixit.com/igo/video/ifixi...)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개:
@alexdrenea what happens when you disconnect the ribbon cables from the panel? There should be two coming from your main board to the panel. Try one at a time.
If you disconnect the mainboard from the power board do the backlights stay on? The power led stays on the whole time and dies not blink?
It is the mainboard that tells the power board to turn the backlights on etc. This sounds like it could be an issue with the new msin board. What vehavior to you get from the TV with the old main board. What exact voltages do you get? Post some pictures with your question of all of your boards so we can see what you see
Thanks for the response. Here are some details:
1. With the Original board.
- with everything connected -> no red standby light, no movement
- with mb disconnected from power supply -> backlight turns on, no red standby light (can't turn on since it gets power from mb)
- with mb connected back -> back to dead
2. With the new main board:
- with everything connected - weird behavior described in the post (back light on and off, red light on and off, buzzing noise from power)
- with mb disconnected - backlight turns on (no red standby light)
- with mb connected and ribbon cables disconnected - same behavior as with the ribbon cables
Which measurements should I take again? I checked the power-mainboard connector voltages and all voltages were good as I've seen in other similar posts here. I can take them again if relevant.
@alexdrenea Post some pictures with your question of all of your boards so we can see what you see. WE need to figure out where the power line for the LCD panel is. 기존 질문에 이미지 추가하기
@oldturkey03 Thank you! I have added image and a video of the behavior.
Note that in my images, I have removed the speakers and wifi module, just so they are out of the way but the behavior is identical if they are connected.
댓글 달기
