주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
MacBook 2015 - The screen is flickering with horizontal lines
Hello everyone!
I have an issue (see below) on the screen if anyone could help me with the solution or at least with the diagnostic – I thank you in advance!
MacBook (Retina, 12-inch, Early 2015)
Processor 1,2 GHz Dual-Core Intel Core M
Memory 8 GB 1600 MHz DDR3
Graphics Intel HD Graphics 5300 1536 MB
Model A1534
Issue:
The screen is flickering with horizontal lines.
On the black appears blue Lines and on the white appers yellow lines (check attached photos).
The issue occurs even using the power outlet or using the battery.
Actions to try to fix:
·      PRAM and SMC reset (several times);
·      Diagnostic mode does not show any problem;
·      macOS reinstallation.
Findings:
·      In safe mode the issue does not occurs (Why?);
·      If a second display (VGA) or TV (HDMI) is plugged (using the single USB-C port) the issue does not occurs too (Why?).
Any tips will be welcome.
Thank you!!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Solved!
Thanks to mxmln23 on that link:
https://discussions.apple.com/thread/251...
The solution is to use a HDMI Dummy Plug, i. e., a display emulator that cost some bucks.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You’ll need to do one test here to nail this down, using an external monitor via the the USB-C port in mirror mode. Then when the condition is present does the external display also see these artifacts?
I’m suspecting they are not present which points to the internal displays logic. The fact when you are running in Safe mode also suggests the T-CON logic within the display can’t support the higher scan rate when the OS fully loads.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi Dan,
I've done the test and the MacBook screen neither the VGA monitor present the condition, i. e., the flicker lines.
Could you please explain a little bit more about the T-CON.
Is it possible to lower down the scan rate? (Even using terminal command or third party app)
Thanks
@whmu - The T-CON is the part which drives the LCD panel of the display within the lid assembly. Basically it converts the Logic board signals to what the LCD display needs to present the image to you in conjunction with the backlight.
Sorry I don't know of any way to over-ride the scan rate the OS wants to use with the internal display. You really only have the Display preference settings. If you have an external display you can often set the scan (resolution) within it. I often do that with my 32" display.
댓글 달기
답변을 추가하세요
WHMU 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 365
