주요 콘텐츠로 건너뛰기
The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
The proper size is PH0
댓글 달기
First get the screw out and take them into a hardware store or electronics parts place and have them get you placements and then reinstall using the proper sized screwdriver
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try soldering iron and twist with your screw driver
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
KingCool 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 25
전체 시간: 445
