주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
White Line in phone
My Phone has white line in the middle of the phone screen. how to remove this white line from phone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Jiwan Kumar, extraneous lines on smartphone screens are usually an indication that the screen has failed and needs to be replaced. Of course, before you do that it will be worth your time to try and reset the phone, and if that doesn't help you should back it up then restore it to factory settings and see if that helps.
If you add a photo of the problem you're seeing on the screen that may help us with diagnosing the issue, but based on just what you've said it sounds like you should replace the screen.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Middle me ha line white
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
JIWAN KUMAR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 170
