주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Samsung Galaxy Note20 Android smartphone. Released in August of 2020.
Device is not charging with cable but charges wirelessly
Hello, my note 20 stopped charging via usb cable, I tried to chage it wirelessly and it works. I thought it was a charging port issue so I gave it to a local shop to fix it and they said it's the capacitor.
I'm not an expert but if the capacitor is failing then why is it charging wirelessly?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi Sohaib,
I understand your confusion and actually tend to agree that in most cases if the wireless charging works but the wired port doesn't, the normal fix is to replace the charging port. On your phone it's relatively straight-forward; the charging port is on a ribbon cable all by itself so changing it doesn't affect anything else in the phone.
However, I guess it depends how much trust you have in the repair shop. I would assume the first thing they would have tried would be to replace the charging port, and it sounds like they most likely did that but found that it didn't fix the problem. Although ultimately the wireless charging signal and the power coming from the USB port both have to make their way through the charging IC in the phone to get to the battery, there are different electronics in play before they get there, so it is indeed possible for this to be a motherboard issue, specifically a capacitor in this case,.
You could try replacing the charging port for yourself; it's not too bad of a job, although that rear cover is really glued on well on those Samsung phones, but if it's been opened recently it might not be as difficult as normal. Here's the iFixit guide showing you how to do that job.
Samsung Galaxy Note20 USB-C Port Replacement - iFixit Repair Guide
Of course, you could also take it to a different shop and get a second opinion; different shops have different levels of expertise so not all shops can fix all the same problems. If they correctly identified a particular capacitor as the problem and have the equipment and expertise to replace it, it's not all that big of a job, but I assume they don't do board level repairs. You might consider finding a shop that does if a new charging port doesn't do the job.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello Jerry,
thank you for your reply.
Unfortunately I don't have the equipment nor the experience to change the charging port myself.
I wanted a second opinion because I don't have much trust in local shops in my twon as they have a bad reputation.
I also wanted to know if the charging circuit board is replaceable. Instead of replacing the capacitor and that requires a lot of experience.
댓글 달기
답변을 추가하세요
Sohaib Muallemi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 110
전체 시간: 2,257
