I can't send message for Friends
I can't send message , how can i send my massege
์ข์ ์ง๋ฌธ์ ๋๊น?
์ข์ ์ง๋ฌธ์ ๋๊น?
@belayzeleke you are not giving us a lot to work with here. It would be nice to know if this just started all of a sudden or if this started after an update etc. Also, does everything else work the way it should or does your phone have other issues as well. For now I suggest you try a force restart to reset your phone. You do that by
See is that did anything.
IF that did not do anything then you want to try to text in safe mode. Safe mode disables all third party Apps that may be the cause for this.
Now send a text to yourself so you know you are receiving it. If so, then you know that this is a third part App that is causing the Texting not to work.
If it does not, then it is possible that this is a network settings issue. You may have to reset those.
For more on this, check the Samsung site
์ด ๋ต๋ณ์ด ๋์์ด ๋์๋์?
์ง๋ 24์๊ฐ: 0
์ง๋ 7์ผ: 4
์ง๋ 30์ผ: 23
์ ์ฒด ์๊ฐ: 149
