주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 최고급 스마트폰. 10월 13일에 발표되어 11월 13일에 출시된 iPhone 12 Pro Max는 6.7형 OLED 디스플레이, LiDAR가 탑재된 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 11 Pro Max의 후속 제품입니다.
Software screen burn issue linked with IOS
I assumed the screen burn was due to excessive brightness on one static image that burnt the pixels in on this iPhone. I replaced the OLED and the screen burn is still there! Its a common issue in the new iPhone 15's and an IOS update was meant to fix it. I have tried restoring, flashing and updating. Nothing has helped. Has anyone had a similar issue and know of a fix, its quite frustrating that I now have a new screen that looks like its got a defect.
It is not a screen issue I have checked with another genuine display and it displays the same burn in on this one too. Seems to be programmed into the software. Anyway of wiping IOS completely and installing fresh?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hi everyone! I bought the new iPhone 15 plus and it has been lovely. However, les got the same problem within 1 month after having it, noticed that the home bar and also the top indicators for the celular, WiFi and signal etc started to get slightly “burned” on the screen when dark mode is enable or every time those icons are displaying a white color.
After using Instagram, for example, for more than 10 minutes (or sometimes less) I can see those icons really visibly burned on the screen, being that after a while, it goes away, but never fully (this is easier to see against a grey background).
I wanted to know if this is normal behavior for an OLED panel, or if I had the bad luck of having a faulty screen. I also wanted to know if someone else has the same behavior on their iPhone. Thanks!
Ps- I also visited service center and give my phone for 7 days for test ajd they didn't find anything regarding this so they just returned my phone!
Hi everyone! I bought the new iPhone 15 plus and it has been lovely. However, less than 1 month after having it, I noticed that the home bar and also the top indicators for the celular, WiFi and signal etc started to get slightly “burned” on the screen when dark mode is enable or every time those icons are displaying a white color.
댓글 달기
답변 2개
선택된 해법
I have managed to solve the issue but won't remove this question in case someone else is experiencing similar problems. This is what I have done that has worked for me
  • Make sure display connector is clean and installed correctly
  • Force restart phone
  • Update IOS through settings (17.1.2, Apple said this will patch this issue)
  • Try updating to public beta patch if regular does not work
  • Enter DPU mode and restore phone through itunes (My restore didn't want to download IOS firmware so I downloaded latest firmware from 3utools (17.1.2 in this case). Left click on restore whilst holding shift on itunes to open folder with system file. Continue with process.
  • Flash phone (Only as a last resort and at your own risk) I used 3utools
Always back up the device if you have important files/data before attempting
What worked for me in the end was the DFU itunes restore with the 3utools firmware, which booted with the same problem. I then tested a few displays on the phone (all which gave the same issue). I then put the replacement screen back and restarted which suddenly solved the issue. No more screen burn and I'm not 100% on what solved it but I can share the process which may help someone 🙂
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
The same thing happens to me, I have an iPhone 12 Pro in iOS 17.2.1 and it has the same problem, since previous versions. I compared with 3 other iPhone 12 and an iPhone 13 and they also have that problem, so it's not hardware but software. I don't know how Apple hasn't been able to fix this error. I hope you solve it in ios18
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 67
전체 시간: 1,653
