주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
Trackpad works but the top layer has detached
On my Late 2016 MacBook Pro (A1707), the trackpad works but the top layer that is visible, is detached on the right side. Is it possible to fix this without removing the battery?
I’m wondering if could mount some double-sided tape underneath the track pad on the right side, not pretty but might work.
Update (12/06/23)
Hi Dan, thanks! CoconutBattery reports: Full Charge Capacity: 95%; Design Capacity: 49%; Cycle Count: 719; macOS Battery Status: Good
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Well how about checking the battery as just based on its age its likely its time for a fresh battery. I would install CoconutBattery and make a fresh Question in Answers so we can check it out together.
댓글 달기
답변 1개
선택된 해법
I’m going to assume this is the original battery, while Cycle Count: 719 is on the edge, the Design Capacity: 49% tells me this battery is not healthy!
So… if you still want to use this system it makes sense to replace the Touchpad and the battery you’ll easily get a good six more years of use!
Review these guides:
Here’s the needed parts:
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar. 이미지
제품
MacBook Pro 15" Retina (Late 2016-2019) Trackpad
$54.99
Replace a 6670 mAh battery compatible with MacBook Pro 15" Retina Late 2016 to 2017 A1707 model laptops. 76 Watt Hours (Wh). 11.4 Volts (V). 이미지
제품
MacBook Pro 15" Retina (Late 2016-2017) Battery
$134.99
MacBook Pro 15" Touch Bar Late 2016 배터리 이미지
안내서
MacBook Pro 15" Touch Bar Late 2016 배터리 교체
난이도:
어려움
1 - 3 hours
MacBook Pro 15" Touch Bar Late 2016 Trackpad 이미지
안내서
MacBook Pro 15" Touch Bar Late 2016 Trackpad Replacement
난이도:
조정
1 hour
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I wanted to replace the battery anyway, but not right now. I fixed the trackpad using two small patches of double-sided tape in each corner, which works well. I'll look at it again when I work on the battery. Thank you for the links; very helpful!
@togedo - I understand it’s a bit of change. In the meantime make sure you backup as one day you might not have access until you fix things.
If your set please accept the answer- Thanks!
댓글 달기
답변을 추가하세요
togedo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 156
