주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
Screen turning on after screen replacement
I've just replaced the screen on my iphone 11 and everything is mostly working fine except the screen is turning on about every 30 seconds. It then auto-locks just like normal and repeat.
I did lose two screws during my repair, the Y screw in the speaker sensor assembly and one of they Y screws on the battery connector bracket.
I haven't reopened the phone yet to see if anything else looks damaged. I'd like to avoid that so I don't need to replace the adhesive again.
What would you suggest doing next? Can you tell me what component my be affecting the screen this way?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sometimes a faulty LCD with ghosting issues can cause this. It turns on as an effect of 'thinking' the lcd was touched. I have had multiple displays doing all sorts of things by itself.
Try with another LCD - initially only connecting the LCD and not the FACEID flex. See if it turns on now. If it doesn't, try to install the flex cable as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
kylewd12 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 253
