주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
After replacement of screen and dock, display shows only blue stribes
Hello,
I dropped my Iphone 4 and it cracked, and in an attempt to change the front screen, I ruined the dock connector. I got a new screen and dock, and have replaced them both, but unfortunatly now I cant turn on my phone. The sounds go on when i turn it on, but the display shows only a black screen with one blue stribe in the middle.
I miss my phone, pls someone tell what could be wrong?
Thx, Louise, Denmark
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Hi Louise,
It sounds like the LCD screen is damaged. Depending on the level of quality of replacement part it could have been faulty to begin with or you have damaged it during installation.
I would recommend taking the phone apart and inspecting the front assembly again. First check that the flex cables are not damaged (which i doubt they are in this instance).
Then check the back of the LCD screen - a common mistake is to screw the left most screw of the wifi EMI shield in too tightly. By doing this the screw puts allot of pressure on the top left of the back of the LCD screen and creates an indent - causing permanent damage to the LCD screen.
Please see this picture for a return we had where the customer had done just this.
http://db.tt/HGtXhrS2
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Malou86 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 1,882
