주요 콘텐츠로 건너뛰기
갤럭시 A14는 삼성이 2023년 1월에 갤럭시 A13의 후속으로 출시한 저가형 슬레이트 안드로이드 스마트폰입니다. 모델 번호 SM-A145(그 뒤에 버전/이동 통신사별 문자)로 식별할 수 있습니다.
How can I remotlychange screen lock password
How can I reset a lock screen password remotely?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Screen lock passwords/patterns are always local to the given device, as such they can’t be remotely accessible. A server or service password is a different story.
Bottom line you need access to the device and you need to remember the password/pattern needed to unlock the phone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
While you cannot remotely change the screen lock password most devices do support remotely locking them until (hopefully) physical access is restored and you can manually reset the password on the device. One of the unique things about Samsung's version of this is that when you remotely lock a device you can also set a new Pin to use when you do recover the device. This is a single use Pin so it is not exactly the solution you are requesting but might help depending on your specific use case. Below is the step by step guide on Samsung's website on how to do this (you do need to have this device registered to your Samsung account and it has to be be on and connected to a network).
https://www.samsung.com/latin_en/support...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Matt Jella 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 189
