Both brewing options pump the same amount of water
Hi. After cleaning/descaling the machine, both brewing size options pump the same (larger) amount of water. Is there a fix for this?
좋은 질문입니까?
좋은 질문입니까?
Try resetting to factory settings: Switch it Off, then On again and press and hold the "Lungo"-button for 5 sec. (The right one). The button should flash three times. The machine will heat up as before - and hopefully the issue has disappeared. Here a Video.
이 답변이 도움이 되었나요?
Thank you; that was what it needed 🙂
Well done! Small cause, big effect. ;-)
지난 24시간: 2
지난 7일: 2
지난 30일: 9
전체 시간: 215
