주요 콘텐츠로 건너뛰기
How to disassemble the screen to replace the LED matrix cable?
How to disassemble the screen to replace the LED matrix cable? (Gigabyte Aero 16 RP86 XE4)
Update (01/11/24)
I need to disassemble the screen to replace or restore the cable
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
Hello, You mean the led strip for display backlight?
Iam not 100% sure but this model should have oled display, thats mean no backlight LED is there.
Hi! Did you manage to fix your issue? Did you dismantle the whole thing, or could you find a replacement cable?
댓글 달기
답변 1개
가장 유용한 답변
The plastic frame should be glued, try to heat the display housing little bit and remove the frame... when is oled display you can use also alcohol for make easier remove the glue
Update (01/11/24)
First remove the hinge part
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Sergei Diev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 728
