주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
Hard Drive and Blade Flash Drive upgrade
Hi.
Can I upgrade the 1TB HDD and the 32GB Flash storage in my iMac 21.5" 4K Retina 2017?
I am opening up the iMac to upgrade the RAM & HDD to SDD and would also like to upgrade the 32GB Flash storage with OWC Aura Pro X2 SSD
I will be running MacOS Ventura 13.6 and I believe the Firmware combines the 2 Drives into 1? I intend to install the OS on the new SDD and leave the OWC aura-pro-x2-ssd for use as explained in https://en.wikipedia.org/wiki/Fusion_Dri...
Im unsure if I'm on the right path as there are a lot of conflicting advice.
Thank you
John
Replace or upgrade the PCIe solid-state drive in a variety of Macs. 이미지
제품
OWC Aura Pro X2 SSD
$199.99
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hey there,
Regarding the hardware you've chosen, you should be on the right track. I'll also link you to iFixit's recommended RAM and secondary SSD upgrade kit. You should be completely fine if you've got your macOS Ventura installation image ready.
Max your iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) with 32 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac. 이미지
제품
iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) Memory Maxxer RAM Upgrade Kit
$251.99
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit. 이미지
제품
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
$82.99
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My main concern I would appreciate advice on is upgrade of the 32GB Flash storage with OWC Aura Pro X2 SSD?
And I would prefer to go with an Internal SSD rather than an External SSD as is would be less prone to failure and I will the iMac fully torn down
Any advice would be appreciated
John
댓글 달기
답변을 추가하세요
John Loch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 133
