GPU Heatsink temperature does not appear
Guys, is there any way to read the GPU Nvidia 9400m or GPU Diode temperature on the iMac? From what I remember, I could only see the temperature in the High Sierra.
좋은 질문입니까?
좋은 질문입니까?
Well… I think you found a weakness in the shim service as TG Pro (or likely any temp monitoring app) can’t gain access to the needed firmware API call.
I hit that too with a few custom Apps with OpenCore. Sadly I ended up rolling back to the highest Apple supported macOS my system could use.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 119
Are you using the latest versions of TG Pro?
DanJ 의
@danj Yes, 2.89. From what I remember, I was never able to see the GPU temperature when installing a system above high sierra, using a patch.
In High Sierra I can see the temperature, but in Catalina onwards I can't.
Ramon Ferreira 의
@ramonferre18311 - What patch?
DanJ 의
@danj At the time of Catalina it was the Catalina Patcher Dosdude1, and currently OpenCore Legacy Patcher, but if I install the official High Sierra I can see the temperature.
Ramon Ferreira 의
